Old 10-18-2009, 01:25 PM   #1
Woodburner blowers will not turn on
Hey guys. New to the site. Looks awesome!
I am having a problem with the blowers on my woodburner. They do turn on but it seems like I really have to have the burner running balls to the wall for the blowers to trigger. Seems like I'm wasting a lot of heat! Also, the blowers turn on and off frequently for some reason (When I have a good fire going). I am guessing it ALL has something to do with the thermodisc relay that triggers the blowers at a certain temp. The disc installed is a T-O-D60T12 120-130 degree F. Do you guys think this is the problem? Is it faulty from the factory or do I just need a different temp thermodisc? Thanks guys!!!
William1382 is offline   Reply With Quote
Old 10-18-2009, 02:14 PM   #2
Hvac Pro
They get old, stiffen up and lose their accuracy (sounds like me, LOL). They are a simple bimetal disc and don't last forever. I would get a new one.
Old 10-18-2009, 03:12 PM   #3
It never did work properly. Hard to say how long it sat on the shelf too tho?
Old 10-18-2009, 03:26 PM   #4
Hvac Pro
We used to have them for limit controls and they were notoriously inaccurate. Graingers/Johnstone may have them.
Old 10-18-2009, 05:09 PM   #5
I will look them up. Thank you for the help yuri!
Old 10-20-2009, 07:10 PM   #6
Hi William I have the same problem with mine but I just fixed it, go to allied electronics the have all kinds of thermodisc, my stove is from usstove and the disc they put in is just to hot, I put in one that closes at 110 and opens back up at around 90, works great I am not losing all that heat anymore, remember that they start when they close and turn off when they open I ordered mine backwards the first time, good luck. Wally
jd720 is offline   Reply With Quote
Old 10-23-2009, 04:55 PM   #7
thanks wally! i will try just that!
More On This Topic
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today I would like to talk to you about the proper use and maintenance of a leaf blower. The first step in getting your gas powered leaf blower to start is to turn on... Read More »
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today I would like to talk to you about the proper use and maintenance of a leaf blowers. On most gas powered backpack blowers or gas powered leaf blowers, the throttle... Read More »
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today I would like to talk about the proper use and maintenance of a leaf blower. The electric leaf blower is very simple to operate. It is just a simple matter of just... Read More »
Hi, I?m Danny from Tampa, Florida and on behalf of Expert Village I?m going to show you how to use and maintain a electric hand drill. I?m going to talk to you have the trigger, the trigger control. These drill every drill pretty much has a trigger speed... Read More »
Hello! This is Chef Sean Roe on behalf of expertvillage.com. The next step in our egg Benedict is to prepare our poaching water. Poaching water is a water that does not go over 200 degrees, so it never boils. Though it is hot enough to coagulate the... Read More »
blower won't turn on when heat is on, but will turn on when AC is on wavelength HVAC 6 12-31-2009 05:06 PM
Fan and A/C unit won't turn on cadmanim HVAC 1 06-22-2009 03:49 PM
Pilot light button on furnace won't turn whydonchathen HVAC 5 10-06-2008 12:03 AM
Furnace w Cooling unit wont turn off Klatimer HVAC 2 09-19-2008 09:35 PM
Faucet won't turn off etiger Plumbing 1 08-31-2005 03:46 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
