Woodburner blowers will not turn on
3K views 6 replies 3 participants last post by  William1382
Hey guys. New to the site. Looks awesome!
I am having a problem with the blowers on my woodburner. They do turn on but it seems like I really have to have the burner running balls to the wall for the blowers to trigger. Seems like I'm wasting a lot of heat! Also, the blowers turn on and off frequently for some reason (When I have a good fire going). I am guessing it ALL has something to do with the thermodisc relay that triggers the blowers at a certain temp. The disc installed is a T-O-D60T12 120-130 degree F. Do you guys think this is the problem? Is it faulty from the factory or do I just need a different temp thermodisc? Thanks guys!!!
#6 ·
wood burner
Hi William I have the same problem with mine but I just fixed it, go to allied electronics the have all kinds of thermodisc, my stove is from usstove and the disc they put in is just to hot, I put in one that closes at 110 and opens back up at around 90, works great I am not losing all that heat anymore, remember that they start when they close and turn off when they open I ordered mine backwards the first time, good luck. Wally
