Wood Stove Stopped Drawing - HVAC - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 07:23 PM   #1
CDH
Rewards Points: 29
wood stove stopped drawing
I hope this is in the right spot if not will someone please move it, anyhow my woodstove has worked flawlessly for about 8 years and all of a sudden it has quit drawing I took the cap off today and cleaned the 6" stainless steel flue that runs inside of the 8" flue this is actually an insert inside of a fireplace anyway the only thing I can think might be the problem is the insulation that I put around the 6" to make it tight between it and the 8" is not as tight as it used to be, I payed 2 prices for this insulation 8 years ago from a woodstove store as it was supposed to be fireproof insulation my question is could I just use regular fiberglass batt insulation with the paper torn off of course or should I go back and buy more of the supposed fireproof insulation? Or any other ideas as to why this stove just quit drawing, all help appreciated.
CDH is offline   Reply With Quote
Old 02-12-2011, 08:31 PM   #2
Dyoung's Avatar
I am not an expert....and I dont know if Im understanding you correctly...but have you checked the top of the flue? Could be leaves or a something blocking it. Air in means air must go out too.
Dyoung is offline   Reply With Quote
Old 02-12-2011, 08:53 PM   #3
CDH
Rewards Points: 29
I took the cap off and ran a brush up and down the flue cleaning it out today so there is definately nothing blocking the air flow at the top.
Old 02-12-2011, 09:40 PM   #4
HVAC / Plumbing
stack isn't tall enough , too small or neg. pressure is keeping it from drawing
kenmac is offline   Reply With Quote
Old 02-12-2011, 10:17 PM   #5
CDH
Rewards Points: 29
It's definately tall enough and the 6" is big enough as it has worked great for 8 years, can you explain to me about the negative pressure.
Old 02-12-2011, 10:35 PM   #6
HVAC / Plumbing
example of neg. pressure would an exhaust fan. When on it would pull against the chimney
Old 02-12-2011, 11:14 PM   #7
30 year tech
hvac122's Avatar
Have you sealed up anything on the house to make it tighter? It sounds like something has changed and is causing a negitive pressure in the house.
hvac122 is offline   Reply With Quote
Old 02-13-2011, 07:06 AM   #8
DIY staff
Rewards Points: 7,174
Try building a small fire while the doors or windows are open---If it draws fine with a window open,then you will know that you have a negative pressure situation---come back if this works--Mike---
Old 02-13-2011, 07:09 AM   #9
DIY staff
You did check and make sure the flue damper at the stove isn't broken? Mine fails about every 5-6 years.
Old 02-13-2011, 07:56 AM   #10
An old Tradesmen
Rewards Points: 6,098
And don't forget to clean the stove. Its passages could be clogged.
The Following User Says Thank You to beenthere For This Useful Post:
oh'mike (02-13-2011)
Old 02-13-2011, 02:07 PM   #11
CDH
Rewards Points: 29
Problem resolved I was right originally in the fact that the stove and stove pipe were dirty and needed a good cleaning, after putting the firebricks and baffle back in the stove it still was'nt drawing so I went back to square one and after much head scratching I realized I put the baffle in the stove upside down, took it back apart and put it in the right way and it is back drawing like a champ. Thank's guys for all the responces I really appreciate it.
The Following User Says Thank You to CDH For This Useful Post:
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Installing a Wood Burning Stove / Fireplace ddrowe0217 HVAC 3 11-27-2008 04:48 PM
Wood Burner, run stove pipe through floor awalker19 HVAC 7 10-19-2008 10:28 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
