I know most app can't share a flue and I know that a wood stove should not share a flue with an oil burner. But, I have an old home with a center chimney. the chimney has no flue tiles. there is an oil burner in the basement. I want to add a wood stove and use the chimney. I know they can't share a flue but is there a way to
1. add a flue, without having to cut apart half the house
2. split the curent flue into two seperate flues 1 for each app
3. use a liner for 1 and exhaust the other around the liner
My chimney is 16" by 16"od. with no terra cotta tiles. so as long as I use a seperate liner for each appliance then i should be ok. I don't think 2 6" flue liners will fit. Thanks for the help.
Do Stainless steel liners support the heat from a wood stove? Just asking. Also what are the flue diameters of your oil fired furnace and the woodstove? You say the OD on your brick, unlined, chimney is 16 x 16, so if you deduct 4 inches on each side of the chimney -for the size of a brick- you have a usable ID on your chimney of 8 inches x 8 inches. I'm willing to bet that oil burner of yours has a flue diameter of 8-10 inches. Your wood stove should have a flue diameter of 6-10 inches as well. How do you propose to provide the breathing room needed for these two appliances in that one 8 x 8 hole?????
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
