Old 09-15-2011, 07:25 PM   #1
Arrow
Wood Stove Piping
First time wood stove installation here, and I have plenty of questions. I have an existing mason chimney, so I am basically just connecting the stove to a hole in the wall (90 degree bend in pipe).
1. My flue collar is 6" and the mason hole to my chimney is 8". Do I put the increaser at the chimney and use 8" pipe or do I put the increaser at the flue collar and use 6" pipe?
2. What piece attaches directly to the flue collar? And how does it attach? Obviously you cannot put screws through the iron flue collar to attach to the pipe. Does the pipe just rest inside the flue collar?
3. Is it necessary to have furnace cement on each joint? or just the 3 screws?
4. My hole to the chimney is slightly larger that 8 inches. When I put a section of 8 inch pipe into the hole it fits loosely. Is there an adaptor for stove pipe into chimney?
Thanks.
cowboy13 is offline   Reply With Quote
wood stove sharing a flue captainkid28 HVAC 5 01-04-2011 12:05 PM
Wood stove and metal roof problem mesquitemagnoli Roofing 6 12-20-2010 08:56 AM
adding wood stove to boiler flu? wombosi HVAC 7 12-14-2009 06:27 AM
Wood Stove in Basement? dwolek HVAC 4 10-28-2009 09:02 AM
Wood stove ? econdave General Discussion 8 10-17-2007 07:50 PM
