Old 11-06-2007, 05:08 PM   #1
wood stove - chimney liner?
I have a dedicated chimney for a wood burning fireplace, but I really wanted to run a single-wall liner, to protect the older chimney and all.
I've seen the black-pipe 25gauge stuff at retail stores for pretty cheap, then I've had people tell me you have to run stainless at a cost of like $600 for the kit.
The way I look at it, you could just use the darn chimney as is, so wouldn't any heavier steel pipe be better than nothing?
OR am I just being crazy and should just pipe it right into the chimney???
What has everyone else done in this situation?
johnnyboy is offline   Reply With Quote
Old 11-06-2007, 07:14 PM   #2
Eibwen
I dont think its allowed to run the black steel pipe where its concealed as in a chimney as it may rust.
If it does rust and the top of the chimney has a fitting for the black pipe to come out, you'll have a void inside the chimney between the outside of the black pipe and the brick which would allow smoke and carbon monoxide to come back into your house.
You can make a fitting to pipe the stove into the chimey and use as is but it will be a lot harder to clean.
Sammy is offline   Reply With Quote
Old 11-06-2007, 08:45 PM   #3
Also, if your chimney is unlined (just brick and mortar, with no tile) it is not safe to use it with a woodstove. You need either a stainless or tile liner. And yes, they're expensive!
NateHanson is offline   Reply With Quote
Wood stove ? econdave General Discussion 8 10-17-2007 07:50 PM
Chimney Liner vs New Furnace jeff_connors HVAC 4 01-11-2007 01:41 PM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Advice Needed re: Chimney Liner for Oil Furnace Mike_R HVAC 3 11-27-2006 04:04 PM
