-   -   wood stove - chimney liner? (http://www.diychatroom.com/f17/wood-stove-chimney-liner-13119/)
johnnyboy 11-06-2007 04:08 PM
I have a dedicated chimney for a wood burning fireplace, but I really wanted to run a single-wall liner, to protect the older chimney and all.
I've seen the black-pipe 25gauge stuff at retail stores for pretty cheap, then I've had people tell me you have to run stainless at a cost of like $600 for the kit.
The way I look at it, you could just use the darn chimney as is, so wouldn't any heavier steel pipe be better than nothing?
OR am I just being crazy and should just pipe it right into the chimney???
What has everyone else done in this situation?
Sammy 11-06-2007 06:14 PM
I dont think its allowed to run the black steel pipe where its concealed as in a chimney as it may rust.
If it does rust and the top of the chimney has a fitting for the black pipe to come out, you'll have a void inside the chimney between the outside of the black pipe and the brick which would allow smoke and carbon monoxide to come back into your house.
You can make a fitting to pipe the stove into the chimey and use as is but it will be a lot harder to clean.
NateHanson 11-06-2007 07:45 PM
Also, if your chimney is unlined (just brick and mortar, with no tile) it is not safe to use it with a woodstove. You need either a stainless or tile liner. And yes, they're expensive!
