Wood Stove - HVAC - DIY Chatroom Home Improvement Forum
Old 02-03-2012, 02:19 PM   #1
Wood stove
Sorry...ok....If i use a woodstove as my only source of heat (small one story house) I know that most of the heat pools around the ceiling....so, if i install ducts in the ceiling that lead to individual areas in the house...will the heat recirculate itself? Thanks.
UrbanWilderness is offline   Reply With Quote
Old 02-04-2012, 05:11 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,078
Ayuh,.... That's how it used to be done,... With convection currents, 'n venting...
The Following User Says Thank You to Bondo For This Useful Post:
DangerMouse (02-04-2012)
Old 02-04-2012, 06:47 AM   #3
jkv
It wont pick up heat and only blow cool air out and make the house feel cooler waist of time and money
jkv is offline   Reply With Quote
Old 02-04-2012, 06:54 AM   #4
Rewards Points: 13,468
If your looking to warm up the attic so it can cause mold and ice dams then that's the way I would do it.
Old 02-04-2012, 08:05 AM   #5
Rewards Points: 314
It all depends on the house and where the other rooms are. I would not put holes in the walls, but there are door corner fans that could help move that hot air to other rooms. I dont know how well the work, or if they are noisy.... google seach "door corner fan".... just a thought.
bobinphx is offline   Reply With Quote
Old 02-04-2012, 11:52 PM   #6
Rewards Points: 87
I was just shopping for fireplace inserts and the guy was telling me that he had his house set up so that the intake duct for the central air upstairs was located downstairs where the fire place and he used the fire then to warm the entire house.
hellonoko is offline   Reply With Quote
Old 02-05-2012, 10:14 AM   #7
Missouri Bound's Avatar
Just run the furnace fan, it will even the temperature out throughout.
Do you want it your way or the right way?
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
wood stove? canoes General DIY Discussions 13 01-26-2012 09:38 AM
New Wood Stove tuchodi Green Home Improvement 3 01-18-2011 05:12 PM
Installing a Wood Burning Stove / Fireplace ddrowe0217 HVAC 3 11-27-2008 03:48 PM
Wood Burner, run stove pipe through floor awalker19 HVAC 7 10-19-2008 09:28 AM
