Wood Furnace Plenum - HVAC - DIY Chatroom Home Improvement Forum
Old 11-04-2010, 07:41 PM   #1
Mr. Handyman
Wood furnace plenum
My clayton 1600 furnace has a top opening of 13''by18'' I need to use this opening and put a 24''L x 28''W x 30''H plenum.
How do i go about doing this ?
any ideas, suggestions, links, information would be great.
BT
thomba24 is offline   Reply With Quote
Old 11-04-2010, 07:53 PM   #2
Im a N00b Here!
Sounds like you need a sheet metal transition made. If you know how to bend sheet metal, it can be pretty fun to do. If you don't bend sheet metal, it can get expensive in buying new sheet metal! :-)
Do a search for "sheet metal transition kits" online and you will find several that fit your need, or head to a local sheet metal shop, tell them what you need and they can pop it out in short order.
GasFurnaceGuide is offline   Reply With Quote
The Following User Says Thank You to GasFurnaceGuide For This Useful Post:
thomba24 (11-04-2010)
Furnace plenum Brian Wallace HVAC 3 03-04-2010 12:56 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
Adding a stand alone wood furnace to existing duct work vtboy51 HVAC 1 04-01-2009 02:19 PM
Furnace plenum size simonb HVAC 1 01-27-2009 09:09 AM
Add-on Wood furnace billmac HVAC 3 06-18-2008 09:17 PM
