Wood Furnace To Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-10-2009, 06:56 PM   #1
wood furnace to gas furnace
I have a fire chief outside forced air wood furnace the hot air duct coming out of it is 10'' and it hooks into the plenum on my gas furnace. The problem is some of the hot air goes out the hot air duct but alot of it goes down thru the gas furnace and up thru the cold air return. Is there any way to get all the hot air thru the hot air duct?
Arnj is offline   Reply With Quote
Old 12-10-2009, 08:58 PM   #2
seems like your supposed to run the furnace fan continually to distribute the air switch tstat to fan on position
kennzz05 is offline   Reply With Quote
Old 12-11-2009, 05:47 AM   #3
An old Tradesmen
Rewards Points: 6,824
With the furnaces blower running. The wood stoves blower may not be strong enough to keep blowing air into the plenum.
Need a back draft damper to prevent it from going through the return.
Where does the wood stove get its return air from?
Horizontal Venting of Wood Furnace ejfitzpatrick HVAC 2 10-17-2009 06:16 PM
Home made wood burning furnace JustinK HVAC 14 10-05-2009 08:26 PM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 12:23 PM
Add-on wood furnace in a small house? Jim Dam HVAC 1 06-24-2008 01:48 PM
