Wood Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 08:50 PM   #1
wood furnace
I recently purchased a wood furnace add on with the intentions of putting on a small porch. Once unboxed realized that the porch was to small. With that said we moved to the basement. Our basement is all open with one 14" by 24" window. The gas furnace and water heater are vented through an old chimney. Now we can not find a way to pipe the flue for the stove. The walls are brick and our house is two stories. We would eventually like to duct into the exsisting duct work but its really cold here and just want to get the thing going for this winter...bills high. I would like to keep it cheap as possible. If anyone has any sugestions.
ward05 is offline   Reply With Quote
Old 01-06-2010, 10:05 PM   #2
i know someone has some ideas
Old 01-06-2010, 10:42 PM   #3
Probably worth the little bit of money it would cost to have a pro come out and tell you how to do it right. Still can do the work yourself but you'll know how to meet codes and have a materials list.
Old 01-06-2010, 10:42 PM   #4
I am fairly certain you will need to put up a chimney, any place that has codes will require that you have a separate flue for the wood furnace. An interior chimney will work better then an exterior one due to cool chimney/draft issues and the forming of creosote.
meboatermike is offline   Reply With Quote
Horizontal Venting of Wood Furnace ejfitzpatrick HVAC 2 10-17-2009 07:16 PM
Home made wood burning furnace JustinK HVAC 14 10-05-2009 09:26 PM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Add-on wood furnace in a small house? Jim Dam HVAC 1 06-24-2008 02:48 PM
