Wood/electric Furnace Controls - HVAC - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 12:40 AM   #1
wood/electric furnace controls
I want to know how an L4064R 1027 alternate furnace interlock limit control works. Does the wood furnace need to be on to bring the plenum heat to 140F to get it to close the normally open contacts?
The low voltage wiring is a mess. I want to rewire the control circuit. I am concerned that I may cause a short circuit on the low voltage wiring if I make a wrong conection. Can anyone out there give me some tips on how to test the aux limit control?
mildtempered is offline   Reply With Quote
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
wood/electric forced air furnace Jim Pass HVAC 0 09-22-2009 07:39 AM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 12:23 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
