Wood Burner, Run Stove Pipe Through Floor - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2008, 10:12 AM   #1
Wood Burner, run stove pipe through floor
I am very short on cash right now and just found out I wont be able to use my chimney for my wood burner.
To save on money I know there is a way you can run a single stove pipe through my upstairs floor and then use a class A chimney pipe to go through the attic and roof.
How would I do that. I know I can use heat shields. What are the requirments to run a stove pipe through a floor? Building it is not an issue I just dont know whats legal/safe.
awalker19 is offline   Reply With Quote
Old 10-18-2008, 10:25 AM   #2
I have never heard of being able to do what you want. When a woodstove pipe passes through any horizontal structure (floor or ceiling) it is normally required to transfer to double or triple wall pipe. Check with any fireplace business in your area for local codes. Also, be sure to check with your Homeowners insurance. I checked and found that a wood "stove" (freestanding unit) would raise my rates by 10% while a built-in fireplace would not raise it at all.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-18-2008, 10:29 AM   #3
Rewards Points: 270
You need to check with the stove manual. But I think you need a class A once you hit the first ceiling.
The people on hearth.com will know also... but they'll tell you to look at the manual.
Class A chimney as you know is not cheap. Also the chimney goin through your 2nd floor is going to need to be boxed in so nobody/nothing can accidently touch it.
pcampbell is offline   Reply With Quote
Old 10-18-2008, 02:55 PM   #4
Whew, no offense, but have the fire dept. phone number handy.
If you have the jitters about doing it and don't know where to get assistance you may want think twice and go a little in debt to have a pro do it.
Than there is the permit, caught with an install with out one on a wood-burner around here is big bucks fine and if you can't afford to correct violations your only other choice is to dismantle the whole job.
hvaclover is offline   Reply With Quote
Old 10-18-2008, 10:22 PM   #5
An old Tradesmen
Rewards Points: 6,876
You'll need an all fuel chimney.
They aren't cheap.
You can't just run a single wall pipe.
Old 10-18-2008, 10:58 PM   #6
They aren't cheap.
gee Been, not even schd 40 PVC?
Old 10-19-2008, 06:29 AM   #7
An old Tradesmen
Ok, schedule 4001 PVC could be used.
Old 10-19-2008, 09:28 AM   #8
~snicker~ that'd look like an Atlas rocket next to the house.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 12:48 PM
Wood Burner Installation Question? fisher501 HVAC 1 12-22-2005 09:29 PM
