Wood Boiler Set Up - HVAC - DIY Chatroom Home Improvement Forum
Old 09-25-2009, 09:35 PM   #1
wood boiler set up
Hello I am currently putting in a indoor wood boiler. It will be used with a Hot air furnace. I currently have everthing plumbed with no problems. I have a heat exchanger that is in the ductwork. My question is how do I get the fan of my Bryant plus 90 gas furnace to come on & off with a separate thermostat? Can I just wire the second thermostat to the G & R terminals? I want the gas furnace to still take over the heating requirments if the fire goes out.
Thanks,
Scott
sruchar is offline   Reply With Quote
Old 09-26-2009, 05:44 PM   #2
Use a relay so the low voltage circuits stay separated.
SKIP4661 is offline   Reply With Quote
Old 09-26-2009, 06:57 PM   #3
wood boiler set up
I was thinking of wiring in a relay like you said. But what will happen if I run 110 volts into the motor that already gets 110 from the furnace? Would I need to put in diodes?
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
circulating pump install for wood fired outside boiler tiltd General DIY Discussions 2 08-27-2009 12:45 PM
Electric Boiler Merged w/ Wood Stove Radiator westphaltyler HVAC 1 03-23-2009 11:44 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
