Won't Run.. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-20-2012, 05:02 PM   #1
Won't run..
Hi there..looking for some help.
I have a carrier model 38TK024300 that won't work. Used to run great, then started to start and stop and would hum. Now it doesn't make a noise or move. I replaced the capacitor and still get nothing. Any suggestions would be helpful. Thanks!
Zee720 is offline   Reply With Quote
Old 08-20-2012, 05:22 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Inside or outside unit? Which part exactly?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 08-20-2012, 05:26 PM   #3
It's a outside unit. Not sure about part. When it was humming I don't know if it was the fan or compressor? The fan blades still move freely, but the unit it's self doesn't do anything now. Guess I'm looking for suggestions on where to start looking.
Old 08-20-2012, 06:07 PM   #4
Checking is a simple process of elimination. Is there 240V at the line side of the contactor. Is there 24V at the contactor, if not is there 24v at the thermostat wires at the AC?
The source of the 240V is the breaker/fuse panel in the house. The source of the 24v is the transformer in the furnace/air handler. Start on the AC end and work your way back to the sources to find which component is dropping voltage. Starting at the AC end lets you eliminate large blocks of potential problem causing components at a time.
The Following User Says Thank You to Marty S. For This Useful Post:
plummen (08-20-2012)
Old 08-20-2012, 11:49 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Is there any humming from contactor in outside unit being pulled in?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 08-21-2012, 10:10 PM   #6
Rewards Points: 614
must be fixed......
carmon is offline   Reply With Quote
Old 08-22-2012, 08:24 AM   #7
No not fixed yet..haven't had time to look at it yet. I'll let ya'll know what I find..thanks again!
Old 08-23-2012, 09:08 AM   #8
Rewards Points: 154
start and stop
Sounds like a bad contactor
Patrick Eubanks is offline   Reply With Quote
