Woman Needs Help Lol Thermostat Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 09:37 AM   #1
Red face
Woman needs help lol Thermostat problem
I had a friend come over and install a new programmable thermostat. The new one only ran the heat. When he put the old one back on, that only ran the heat too. Everything (heat, fan, A/C all ran fine before new one was put in). I have replaced the new old with the old one again and still no A/C or fan. Only heat..... Any suggestions?
balou2u2 is offline   Reply With Quote
Old 05-30-2011, 10:43 AM   #2
Rewards Points: 6,652
model# of old thermostat, model# of new thermostat, do you have a heatpump. Post pictures of the thermostat, and the connections with their colors on the air handler. If everything was hooked up as they were on the old thermostat, then someone did not read the installer instructions in setting up the new one for your system.
The Following User Says Thank You to gregzoll For This Useful Post:
balou2u2 (05-30-2011)
Old 05-30-2011, 11:36 AM   #3
Old one is a Honeywell (can't find model #), new one is a hunter 44110. I'll see if I can post pics. Thanks!
Old 05-30-2011, 11:37 AM   #4
Take back the Hunter and get a Honeywell. Hunters are not good thermostats.
Old 05-30-2011, 11:44 AM   #5
Hope this helps
Woman needs help lol  Thermostat problem-new-thermo.jpg   Woman needs help lol  Thermostat problem-wires.jpg   Woman needs help lol  Thermostat problem-0530111233-00.jpg
Old 05-30-2011, 11:45 AM   #6
I have a forced air furnace (not sure what a heat pump is)
Old 05-30-2011, 11:54 AM   #7
The Heat pump sits outside. Looks like a air conditioner, but it allows the heat to be pulled from outside when it is cold out, and runs like a ac during warmer months. Compare the wire connections and color on the thermostat to what they are like on the air handler. Use a sheet of paper to put down on one side the connections at the thermostat, and on the other the connections at the air handler. From there it should hook up. Also make sure you have batteries installed in the thermostat, and when you make the connections make sure the power is shut off on the air handler, so that you do not blow any fuses.
Once connected, going through the programming is all you have left to do.
Old 05-30-2011, 11:55 AM   #8
The Honeywell (old thermo) is a ct3400
Old 05-30-2011, 12:01 PM   #9
I don't think so. All that I see is the ac unit
Old 05-30-2011, 12:02 PM   #10
The old one worked fine..... wish it would work again
Old 05-30-2011, 12:02 PM   #11
If it ain't broke - don't fix it lol I should have followed this rule of thumb lol
Old 05-30-2011, 12:06 PM   #12
what is an air handler and where are the wires? lol
Old 05-30-2011, 01:40 PM   #13
Depends on if you are in a home or apartment. Could be in a closet, your attic, or a space that you need maintenance to get to if you are in a condo. The wires would be in the bottom of the unit where the fan is for moving the air across the coil & heat exchanger.
Old 05-30-2011, 01:44 PM   #14
I am in a mobile home. The heater/Fan is in a closet but I can't make heads or tails of all the wires
Unbelievable, Thermostat setting changes by ITSELF notawiz HVAC 38 07-25-2014 08:38 AM
Problem w/ two 240v baseboard circuits on single double-pole switch. Skypalace Electrical 18 03-21-2010 04:16 PM
Thermostat or oil burner problem? freyguys HVAC 5 02-25-2010 01:44 PM
Changed thermostat and have problem ssmcalister HVAC 3 10-29-2008 04:40 PM
Hunter Thermostat Problem kohlernm HVAC 1 11-22-2007 09:58 PM
