Wiring Trouble - HVAC - DIY Chatroom Home Improvement Forum
Old 03-22-2012, 02:08 PM   #1
Wiring trouble
I have a Rheem heat pump unit that burned the 24VDC transformer out. I replaced it and burned the replacement up. I replaced it again and took a 3 amp breaker and placed it between the thermostat wires and the outside unit. I found that 1 of the wires that goes directly from the thermostat to the outside unit trips this breaker when I start the unit up. I tested by running new wiring and found that the wiring is okay. But I do not know what is causing the problem. Is it the thermostat or the board in the outside unit? Any help would be greatly appreciated. I have a 6 wire heat pump thermostat. Wire is Y that is giving me trouble.
gspldrumr43 is offline   Reply With Quote
Old 03-22-2012, 07:07 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
Most likely it is the contactor...........
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-24-2012, 12:05 AM   #3
i would have to agree sounds like you have a shunt contactor meaning your contactor is grounding out
heatingman is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 01:17 PM
Unusual three way switch wiring help r1racer Electrical 9 11-11-2010 09:49 PM
trouble wiring ceiling fan schnaity Electrical 6 08-25-2008 09:37 PM
wiring trouble? brad25 Electrical 5 11-27-2005 07:07 PM
