Wiring A Thermostat To Run Fan Motor. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-05-2012, 10:24 AM   #1
Wiring a thermostat to run fan motor.
How do you wire a thermostat to run a fan blower only on a gas furance
Kedro is offline   Reply With Quote
Old 10-05-2012, 10:34 AM   #2
Missouri Bound's Avatar
It's not always possible. If a thermostat has a fan switch AND the furnace control allows it you should be able to make it work with simple thermostat connections. The control board of the furnace will be ready for this connection. What wires are you working with to the thermostat? Got a picture? What connections are at the furnace?
Do you want it your way or the right way?
Old 10-05-2012, 11:57 AM   #3
how
Rewards Points: 1,070
If your furnace predates a control board, it's still possible to do with a fan relay if you have a thermostat with a fan switch and an available line to carry the switching 24V.
how is offline   Reply With Quote
Old 10-05-2012, 02:50 PM   #4
biggles's Avatar
you have to chase the fan cycle into the heating signal if you have a control module it will come off that on a delay with that black relay board mounted you see with arating tag stamped
Old 10-05-2012, 04:15 PM   #5
AKA HVACTECHFW
Rewards Points: 1,208
More info about your setup is needed to be truly helpful.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Issue with thermostat wiring for baseboard heater jschell Electrical 3 01-30-2011 08:30 AM
heat pump wiring problem - new thermostat tygrr94 HVAC 8 01-17-2011 09:18 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 06:13 PM
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 08:04 AM
