-   -   Wiring a thermostat to run fan motor. (http://www.diychatroom.com/f17/wiring-thermostat-run-fan-motor-159032/)
Kedro 10-05-2012 09:24 AM
How do you wire a thermostat to run a fan blower only on a gas furance
Missouri Bound 10-05-2012 09:34 AM
It's not always possible. If a thermostat has a fan switch AND the furnace control allows it you should be able to make it work with simple thermostat connections. The control board of the furnace will be ready for this connection. What wires are you working with to the thermostat? Got a picture? What connections are at the furnace?
how 10-05-2012 10:57 AM
If your furnace predates a control board, it's still possible to do with a fan relay if you have a thermostat with a fan switch and an available line to carry the switching 24V.
biggles 10-05-2012 01:50 PM
you have to chase the fan cycle into the heating signal if you have a control module:wink: it will come off that on a delay with that black relay board mounted you see with arating tag stamped
hvactech126 10-05-2012 03:15 PM
More info about your setup is needed to be truly helpful.
