Wiring Thermostat For HVAC - HVAC - DIY Chatroom Home Improvement Forum
Old 05-06-2010, 03:17 AM   #1
UncaYimmy's Avatar
Wiring Thermostat for HVAC
Long story short, the prior owner of the house had the thermostat wired where I had to change one wire around to switch it from heating to cooling. Well, I lost my little cheat sheet, which was in Romanian anyway. I want to get it wired properly, but I'm stumped.
My heat pump unit's manual is here (page 40 as labeled):
http://www.dnmech.com/lit/QRP-08.pdf
My thermostat is here:
http://www.luxproproducts.com/pdfs/100.pdf
One thing that confuses me is that in the control panel for the HVAC unit there is a sticker that appears to override what's in the manual above. The sticker shows from left to right:
R G O W1 W2 and then a big Y with what look to be O and C labels underneath for the last two connectors.
Going by the above diagram the hack prior owner tapped into R, G, O, W2, and Y(C) (with telephone wire, which, of course, means the colors don't match at the thermostat, so I have a conversion chart).
Judging by the wiring diagram, I have a one-transformer HVAC. When I wire it according to how I read the thermostat model, I get heat when switched to A/C. By "how I read it" I mean G, Y(C), W2, R with O taped off (it makes sense when you look at the manual).
Any help would be greatly appreciated.
UncaYimmy is offline   Reply With Quote
Old 05-06-2010, 07:33 AM   #2
An old Tradesmen
Rewards Points: 6,464
You need a heat pump thermostat. And that thermostat is not a heat pump thermostat.
Old 05-06-2010, 02:04 PM   #3
UncaYimmy's Avatar
How did you determine that it's not a heat pump thermostat? The manual seems to indicate that it can do it. I'm confused.
Old 05-06-2010, 04:01 PM   #4
lol its clearly stated in that manual YOU posted "cannot be used for heat pump applications" under features
kennzz05 is offline   Reply With Quote
Old 05-06-2010, 04:15 PM   #5
UncaYimmy's Avatar
LOL is right! I went straight to the wiring diagrams and skipped that part. Shame on me! I'm sorry to have wasted everyone's time, but I am most grateful for the smack on the back of the head.
Old 05-06-2010, 04:49 PM   #6
consider yourself smacked
Old 05-06-2010, 06:29 PM   #7
An old Tradesmen
I read the instructions you posted.
Old 05-07-2010, 02:54 AM   #8
UncaYimmy's Avatar
In all fairness to myself, I assumed that the prior owner had purchased something that would actually work. I went out today and bought a proper unit and installed it without a hitch. Again, many thanks for pointing out the obvious!
Old 05-07-2010, 05:51 AM   #9
An old Tradesmen
We have all fallen pray to assumptions, at one time or another.
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 07:11 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Thermostat wiring jetmanaz HVAC 1 08-09-2009 08:13 PM
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 08:04 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
