Old 07-14-2012, 07:58 PM   #1
wiring to thermostat
Hi,does anyone by chance know what the operation of each circuit/wire to thermostat could be on the pic.Is blue usually temp/on off for ac ?.
its a older heat pump/ weathertron.
hidden1 is offline   Reply With Quote
Old 07-14-2012, 09:47 PM   #2
biggles's Avatar
its not the colors it is the letters from there to the stat that are the loads to run
Old 07-14-2012, 09:58 PM   #3
Professional
B = 24VAC common
R = 24VAC hot
Y = COMPRESSOR CONTACTOR
G = BLOWER
O = REVERSING VALVE
T = ODT
W = AUX HEAT
X2 = EMERGENCY HEAT
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-14-2012, 11:02 PM   #4
thanks.
-what is the l (is light blue between the g and o)
Old 07-14-2012, 11:07 PM   #5
Professional
Fault indicator
IT IS WHAT IT IS
Old 07-18-2012, 12:06 AM   #6
Is there usually a wire attatched to this l- fault indicator (coming out as the rest are ) or is it suppose to be without a lead to thermostat..
Old 07-18-2012, 04:29 AM   #7
Only if your thermostat can use it. In my area we rarely see that terminal hooked up.
scottmcd9999 is offline   Reply With Quote
The Following User Says Thank You to scottmcd9999 For This Useful Post:
hvactech126 (07-18-2012)
thermostat wiring rejames HVAC 11 05-02-2012 09:07 PM
2 zone damper 2 thermostat wiring help kostia HVAC 10 08-22-2010 10:57 AM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 07:11 AM
Thermostat wiring question cpuken HVAC 4 12-14-2009 08:32 PM
