-   -   wiring to thermostat (http://www.diychatroom.com/f17/wiring-thermostat-150271/)
hidden1 07-14-2012 07:58 PM
152 Attachment(s)
Hi,does anyone by chance know what the operation of each circuit/wire to thermostat could be on the pic.Is blue usually temp/on off for ac ?.
its a older heat pump/ weathertron.
biggles 07-14-2012 09:47 PM
its not the colors it is the letters from there to the stat that are the loads to run
hvactech126 07-14-2012 09:58 PM
B = 24VAC common
R = 24VAC hot
Y = COMPRESSOR CONTACTOR
G = BLOWER
O = REVERSING VALVE
T = ODT
W = AUX HEAT
X2 = EMERGENCY HEAT
hidden1 07-14-2012 11:02 PM
152 Attachment(s)
thanks.
-what is the l (is light blue between the g and o)
hvactech126 07-14-2012 11:07 PM
Fault indicator
hidden1 07-18-2012 12:06 AM
152 Attachment(s)
Is there usually a wire attatched to this l- fault indicator (coming out as the rest are ) or is it suppose to be without a lead to thermostat..
scottmcd9999 07-18-2012 04:29 AM
Only if your thermostat can use it. In my area we rarely see that terminal hooked up.
