#1 |
Wiring and Thermostat?
With the help of a neighbor, I just installed a new blower motor on my furnace. Furnace is located in crawl space and AC unit is on side of house.
We feel confident we wired the motor correctly. However, on the main panel/wiring panel/sensory panel, White Rodgers 50TC35-730 there is a scanner bar code on a black chip that reads 50T35-730-01 and underneath, B18099-13. The issue is now this, I turned the AC on auto and it worked great! No more short cycling. However it is cool today so I turned the AC to off and the blower continued to run. I checked the outside unit and it was off however, the blower was running strong. I currently have the power turned off to my furnace unit so it would quit running. Am I missing something on the thermostat wiring to the panel? I don't think its my thermostat as I just put in a new one two weeks ago and everything turned on and off correctly so I think we may have mis-wired something below. Please any ideas or help would be appreicated! |
#2 |
furnace model and serial may help.... blower is told to run constant by g take g off stat and see what happens
#3 |
An old Tradesmen
B18099-13, sounds like a Goodman furnace board.
| The Following User Says Thank You to beenthere For This Useful Post: | hvactech126 (05-10-2012) |
#4 |
Let's light the fire and burn the tires! |
| Display Modes | |
| Thermostat for electric baseboard wiring help needed | vae_victis | HVAC | 10 | 01-05-2012 11:53 AM |
| Help Wiring Programmable Thermostat | Brio9 | HVAC | 4 | 02-14-2011 12:25 AM |
| Honeywell thermostat wiring | wcb22 | HVAC | 5 | 01-10-2011 06:54 AM |
| Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System | TekGamer | HVAC | 0 | 07-10-2010 12:58 AM |
| Problem with Lennox Pulse Furnace Wiring to Thermostat | scalvin | Electrical | 4 | 12-30-2009 08:48 PM |
