Wiring A TH8320 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-18-2008, 05:05 PM   #1
Wiring a TH8320
I have a Lennox Air Handler CB 26UH with an outside A/C unit. I am trying to the wire the new thermostat and here are my connections off the old thermostat.
Black goes to E
Yellow-Y
B is skipped
Orange-O
White-W2
Red-R
Green_G
First off do I use the conventional or Heat pump terminals?
When aligning the wires with the terminals do you stay you have to stay under the conventional/heat pump selection or can you just match the wires to the corresponding letter?
If I align all the wires using the conventional terminals, my first wire (Black E) is not an option. It is under the Heat Pump side.
Thanks for any assistance.
Ryan314 is offline   Reply With Quote
Old 12-18-2008, 08:54 PM   #2
An old Tradesmen
Rewards Points: 6,060
Do you have a heat pump, or an electric furnace wioth A/C.
Your old stat was wired as though it were controling a heat pump.
Old 12-18-2008, 08:59 PM   #3
I have a Air Handler with an outside A/C unit.
Old 12-18-2008, 09:04 PM   #4
An old Tradesmen
Ok.
Then I have no idea why your old stat is wired for a heat pump.
So your outside A/C unit doesn't run when the thermostat calls for heat.
Old 12-19-2008, 06:28 AM   #5
The outside A/C unit only runs when I select A/C on the T stat. The heat is produce by the Air handler electrically.
Old 12-19-2008, 06:52 AM   #6
An old Tradesmen
Then on the TH8320.
For an electric furnace.
Red to RH/RC.
Yellow to Y1.
Green to G.
White to W!.
Black to E.
Orange is taped off, only needed if you have a heat pump.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Electrical problem, bad wiring? mumblemouth Electrical 10 08-09-2008 12:52 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
