Wiring A T-stat For My Garage Furnace. - HVAC - DIY Chatroom Home Improvement Forum
Old 01-03-2009, 10:39 AM   #1
Cheapskate
Wiring a T-stat for my garage furnace.
I am a cheapskate.
I am the sectratary of a motorcycle riders club called C.R.A.P. Cheapskate Riders Are Proud.
We thrive on finding ways to save money in modding our bikes but at the same time make them look and preform great.
So I am a cheapskate.
I work in the Natural gas department of a utility and the other day I was working at a house where the 16 year old furnace was being replaced with a new high efficincy model.
I asked what the contractors were going to do with the old one and they practically put it in the truck for me.
So now I have it in my garage.
Its going to be used for heat only never cooling.
The gas and electric has been run to the unit but I dont quite understand how the cheapest and easiest way to put a T-stat on it.
It is a Carrier Weathermaker high efficiency furnace.
It did not come with the 24 volt transformer so I'll go to Menards to get one but I am not sure how to run the wires from the control panel to the T-stat.
Here is a few pics I took, hopefully it helps!.
Thank you.
The wiring codes on the control panel are from left to right:
W Y R C G
Whats the cheapest and easiest T-stat I can use?
klapool is offline   Reply With Quote
Old 01-03-2009, 01:12 PM   #2
An old Tradesmen
Rewards Points: 6,138
Any cheap HD stat, with a common.
PS: you do have it sitting on a pedastal or other support to keep the blower motor 18" above floor, to meet fire code/IFGC, right?
Old 01-03-2009, 03:43 PM   #3
Cheapskate
So is that a 4 wire or a 5 wire? right now I have a 4 wire t-stat.
I have it sitting on cement blocks 20 inches above the floor
Old 01-03-2009, 05:31 PM   #4
An old Tradesmen
If your only using it for heat, and want the fan to run by the thermostat in the summer, 4 wire will work fine.
Old 01-03-2009, 06:11 PM   #5
Cheapskate
Well I think its to late.
I found a stat on the circuit board.
I hooked up the stat as listed for a 5 wire and could not get the unit to run with the exception of the heat fan.
I then looked at the instructions and found a diagram to use a 4 wire set up with the RC and RH connectors jumpered.
I turned on the power and instantly saw a spark from the transformer.
So I guess its toast.
I assume the worst and the circuit board is probabaly gone unless there is a fuse somewhere.
Old 01-03-2009, 07:25 PM   #6
Cheapskate
Sorry I meant xfmr instead of stat
Old 01-03-2009, 10:20 PM   #7
Try this, Take all the wires off of the rh-rc-w-y-c and turn the furnace on. You should get 24 volts between rh and c. If you do the transformer is good. All you need to make the furnace work on heat only is rh and w. If you jumper those you should get heat. The "g" terminal is the manual fan control. If you jumper rh and g the fan should come on.
So if this works you are in business. Connect a heat only stat on rh and w and it should work, unless you toasted the board.
If it's true that you learn from your mistakes- I'm getting one heck of an education
thumbkins is offline   Reply With Quote
Old 01-03-2009, 10:27 PM   #8
Cheapskate
Sorry for being brain dead on this but from what I read, I need to jumper the rh the w and the g for heat and fan.
Please forgive my ignorance.
Old 01-03-2009, 10:39 PM   #9
Then "r" terminal is the positive 24 volts to the stat. The "w" terminal on the stat is the power going back to the furnace to turn on the heat. The "g" terminal is the manual fan control. For heat only all you need is the "r" and "w".
Did you try what I suggested about jumpering the terminals at the furnace board??
Old 01-03-2009, 10:43 PM   #10
Cheapskate
I,Ll go check it right now.
Old 01-03-2009, 10:53 PM   #11
Cheapskate
I don't have a RH but I checked the R and C and I have no voltage at all
Old 01-03-2009, 11:02 PM   #12
O K
You have to check on the board. Sometimes there is a small glass fuse on there. It will look something like the old glass fuses used on cars of the 60's.
Can you get at the transformer? Do you have a voltmeter that shows 110v and 24 volts? If you do you can check the trans. One side (2 terminals ) are 24 volts A C and the other 2 terminals are 110 volts A C.
Now for my dumb question, you did check that there is power going to the unit (110volts).
Sometimes when they spark at the transformer it means the connection is loose and came apart. Give it shot, let me know.
Old 01-03-2009, 11:10 PM   #13
Cheapskate
So do I have to have the safety switch pushed in to get the voltages? If so I'll need to tape it shut.
Ill look for a glass fuse and then check the xfmr.
Old 01-03-2009, 11:17 PM   #14
YES The saftey switch must be pushed in or jumpered or taped down or you won't get any voltage. It is a safety switch.
Old 01-03-2009, 11:19 PM   #15
Check for voltage at the terminals on the furnace with the safety switch pushed in or jumpered or taped.
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Electric Furnace Burned Element Wiring - Cause? Radioguy HVAC 6 12-15-2008 07:55 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Wiring a garage reverendcolin Electrical 34 11-10-2008 05:53 PM
