Wiring Question For Trane Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 09:01 PM   #1
Rewards Points: 45
Wiring question for Trane furnace
I have a Trane XE60 furnace with a Trane air conditioning compressor for cooling. My thermostat has a yellow wire that runs to the furnace and then connects to another yellow wire that goes to my outside compressor. However, while both yellow wires are connected to each other, they are not connected to the Y terminal on the furnace controller.
My heater and air conditioner have worked for years with the wiring this way. My question is - will the system work any differently if I actually connect both yellow wires to the Y terminal?
rvmeush is offline   Reply With Quote
Old 02-27-2012, 09:04 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
It will work the same. The Y terminal is no more than a junction for the two wires. One wire from the condenser goes to Y and the other wire from the condenser goes to C
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
rvmeush (02-27-2012)
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
furnace power wiring question w/photo pirateplow HVAC 1 12-17-2011 06:32 AM
Range Wiring Question - Not Usual Question RWessner Electrical 5 12-04-2010 06:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Question about light in furnace rm Sherpa Electrical 7 12-22-2008 07:10 PM
