Wiring Question For Replacing Compressor Fan Motor For A Two Ton Presidentiol Condensing Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 01:14 PM   #1
Wiring question for replacing compressor fan motor for a two ton Presidentiol Condensing Unit
The original 1/6 hp 230 VAC, 1 phase vertical shaft fan motor has only two wires attached to the Cutler-Hammer C258NB230T Series E Coil 24V 60 Hz Contactor, which also has the capacitor connected to it. The new motor the guy at Granger sold me has four wires. I'm assuming that the coil stays discharged while the motor runs, then recharges when it is off allowing it time to charge. I assume I must combine the four wires to be two. My questions are: Is my thinking correct? Does it matter which coil wire do I connect to which primary motor wire? I'm guessing it does, but I don't know how to choose whice wire to attach to gether.
Charles11 is offline   Reply With Quote
Old 07-14-2012, 01:22 PM   #2
JJboy's Avatar
I have a schematic in my album....check it out.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-15-2012, 09:26 AM   #3
Houston204's Avatar
Rewards Points: 556
What motor did grainger sell you?
What color are your 4 wires?
Green would wire to the unit body or ground.
Houston204 is offline   Reply With Quote
Quick HVAC / sump pump wiring question MattOverMinder Electrical 4 01-23-2009 07:42 AM
Electric question from power pole to unit Slocalaman Electrical 3 11-06-2008 03:23 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Question on 240v to ac(window unit) evosounds Electrical 2 07-20-2007 11:45 PM
central air unit question princessme HVAC 4 07-08-2006 09:13 PM
