Wiring Problems? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 04:39 PM   #1
Wiring Problems?
I have just replace my old furnace with a newer one. It is a Miller Furnace in a mobile home/ trailer. I have installed the furnace, ran the wiring for the blower and that seems to be working fine. I installed the burner and found out the transformer was no good. I purchased a brand new transformer and connected the wires in the same way that the old one was connected. The furnace turns on and creates flame, blower turns on and works, but the furnace will not shut back down. I have tried adjusting the thermostat and I even disconnected the thermostat, still no change. Im wondering if theres a problem with the wiring? Hopefully somebody on here can help me, thank you.
Zacariah is offline   Reply With Quote
Old 10-30-2010, 06:20 PM   #2
HVAC / Plumbing
you must have wired it wrong sending direct voltage to the controls
kenmac is offline   Reply With Quote
Under ground wiring on top of pvc water piping. mcmad2 Electrical 11 08-09-2010 08:02 PM
wiring overkill????? choda_boy_04 Electrical 8 01-01-2009 12:54 PM
1939 House Wiring upgrade jimmyfloyd Electrical 4 10-01-2008 03:56 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
