(Wiring Problem) Switching From MARS2 Control Transformer (CT) To PROTECH CT - HVAC - DIY Chatroom Home Improvement Forum
Old 06-21-2013, 12:17 PM   #1
(Wiring Problem) Switching from MARS2 Control Transformer (CT) to PROTECH CT
First, I would like to thank you for reading my post. Second, my MARS2 control transformer finally gave out, which, of course, stopped my entire HVAC system from working. However, when I went to the hardware store to purchase another control transformer the only kind they had was a PROTECH model.
The PROTECH model has a different wiring scheme from my previous transformer and therein lies the problem which lead me to you.
Originally, my Mars transformer was connected to color for color (Blk to Blk), (Blue to Blue), (White to White) and (Yellow to Yellow). Also, the red and orange wires weren't connected to anything but where taped off at the end.
However, my new transformer has almost the same coloring scheme BUT it has two yellow wires and I have no idea what to do with them.
OLD Transformer
(Wiring Problem) Switching from MARS2 Control Transformer (CT) to PROTECH CT-old-transformer.jpg
NEW Transformer
(Wiring Problem) Switching from MARS2 Control Transformer (CT) to PROTECH CT-new-transformer.jpg
Wiring Diagram
(Wiring Problem) Switching from MARS2 Control Transformer (CT) to PROTECH CT-wiring-diagram.jpg
barksdalec is offline   Reply With Quote
Old 06-21-2013, 03:27 PM   #2
Rewards Points: 154
tranformer
look at the label on the new transformer. It will probably show you that the yellow wires are the low voltage wires. connect one to where the old blue wire was located and one to the old yellow wire location. that takes care of your low voltage side. Next, go to your high voltage side of your new transformer and find out which color wire is your common and hook it to the location that your old white wire was located. The next step is the tricky one. without knowing what type of unit or what voltage is coming into your air handler I cant tell you which wire to hood up. If the black wire was hooked up previously, I assume it is a gas furnace. In that case you will want to look at your new transformer and find the color wire that is 120 volt and hook that one to your old black wire location. Make sure you put wire nuts on the remaining wires. Good luck
Patrick Eubanks is offline   Reply With Quote
Clicking sounds from unknown part between transformer and primary control Notsosuperman HVAC 7 03-07-2013 09:30 PM
wiring pressure switch and control box Vgheal Plumbing 2 10-28-2012 07:54 PM
wiring to control board and thermo stat dijas HVAC 2 10-27-2012 08:56 PM
wiring furnace transformer jasonbaur HVAC 4 10-26-2012 03:44 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
