Wiring New Thermostat To New Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-10-2008, 07:40 PM   #1
Rewards Points: 81
Wiring new Thermostat to new furnace
Hello, I installed a new trane xr90 furnace and would like some help wiring the thermostat. I dont want to short out the board or anything. My furnace has the following connections. C, G, R, W, & Y. I am hooking that to a RTH7000 Honeywell programable thermostat. I will only be using Single stage heat for now but airconditiong in the future. I bought a five conducter themostat wire with G R W Y and Blue. There wasnt a blue on the furnace. Do I just need to hook up G, R W & Y to their prospective spots. Do I need the C terminal and what is it used for? Thanks for all your help.
hartkem is offline   Reply With Quote
Old 11-10-2008, 08:53 PM   #2
Electrician
C is common, if your t-stat has that on it, than you can use it. not sure if your t-stat requires it or not. some do, some dont.
chris75 is offline   Reply With Quote
Old 11-10-2008, 09:17 PM   #3
Rewards Points: 81
Thanks, I just hooked everything up by color and it worked. Why do they use a jumper from RR to R on the stat
Old 11-10-2008, 09:25 PM   #4
If it's got a C (common) you'll need to power the stat. It runs of the furnace xfrm (transformer)
hvaclover is offline   Reply With Quote
Old 11-10-2008, 10:11 PM   #5
Electrician
You mean RC and RH? incase you have a dual transformers, one for heating, one for cooling.
Old 11-11-2008, 08:24 AM   #6
Rewards Points: 81
Ok, that makes sense. All is working ok. Thanks
Old 11-11-2008, 10:48 AM   #7
... and because most setups use just one transfomer the tstats often come jumpered from the factory.
dac122 is offline   Reply With Quote
Old 11-11-2008, 08:09 PM   #8
Electrician
Thanks for the extra explanation.
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 08:04 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
New Thermostat and Furnace Not Working Right Vegas Resident HVAC 1 12-06-2007 07:42 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
