Old 02-24-2013, 02:04 PM   #1
Wiring new Nest thermostat
Hi Everyone,
I'm new to the forum and am looking for a little help. I bought a nest 2nd generation thermostat and will be installing it in a few days. I have a gas furnace with access and 4 wires coming into the old state. This is how it's connected: Red - rc, white - w, blue - y, green - g. No common. Nest says no common wire is needed, but I have read issues with the system stealing power causing problems with furnaces. Is this a valid concern? I am thinking I need the common wire to avoid any issues.
Now I also have 2 wires coming in to the stat area from a humidifier we don't use. Red and white.
Down at the furnace, I have the connections above plus c for common. There are 2 red wires connected there. I'm pretty sure they are for the humidifier and ac.
So my question is does it make sense to run a new 5 wire from the stat to the furnace or steal the humidifier red wire for the common after disconnecting it from the humidifier entirely? Running new wire is a clear shot and doesn't look too bad. Just concerned about messing up the connections at the furnace.
Thanks!
nateonator is offline   Reply With Quote
Old 02-24-2013, 02:48 PM   #2
Houston204's Avatar
I'd pull new 8 conductor 18 gauge wire to the thermostat. This would allow for control of a humidifier or future upgrades.
Remove power to the furnace and write down the existing connections before removing any wires. I'd also snap a few pictures of the wiring.
Houston204 is offline   Reply With Quote
Old 02-24-2013, 03:19 PM   #3
Thanks for the advice Houston. I will see about upgrading the wire.
Old 02-24-2013, 04:57 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
As long as you try to keep some symmetry to the colors (R-Red, G-Green, Y-Yellow, W-White, so on). It is when you use different colors for different terminals, the next person may end up confused if they change it out.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 02-25-2013, 01:38 PM   #5
Post
Originally Posted by nateonator View Post
Hi Everyone,
Thanks!
If your new thermostat is using batteries.. you won't have to use the common wire ( typically blue )
rydan is offline   Reply With Quote
Old 02-25-2013, 08:47 PM   #6
gregzoll's Avatar
You may want to read up on the Nest. It uses a built in Lithium battery, but has problems with charging on certain hvac systems, so you need the C-Common wire to charge the battery in the device.
The Following User Says Thank You to gregzoll For This Useful Post:
hvactech126 (02-26-2013)
thermostat wiring rejames HVAC 11 05-02-2012 09:07 PM
2 zone damper 2 thermostat wiring help kostia HVAC 10 08-22-2010 10:57 AM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 07:11 AM
Thermostat wiring question cpuken HVAC 4 12-14-2009 08:32 PM
