-   -   Wiring new Nest thermostat (http://www.diychatroom.com/f17/wiring-new-nest-thermostat-172850/)
nateonator 02-24-2013 01:04 PM
Hi Everyone,
I'm new to the forum and am looking for a little help. I bought a nest 2nd generation thermostat and will be installing it in a few days. I have a gas furnace with access and 4 wires coming into the old state. This is how it's connected: Red - rc, white - w, blue - y, green - g. No common. Nest says no common wire is needed, but I have read issues with the system stealing power causing problems with furnaces. Is this a valid concern? I am thinking I need the common wire to avoid any issues.
Now I also have 2 wires coming in to the stat area from a humidifier we don't use. Red and white.
Down at the furnace, I have the connections above plus c for common. There are 2 red wires connected there. I'm pretty sure they are for the humidifier and ac.
So my question is does it make sense to run a new 5 wire from the stat to the furnace or steal the humidifier red wire for the common after disconnecting it from the humidifier entirely? Running new wire is a clear shot and doesn't look too bad. Just concerned about messing up the connections at the furnace.
Thanks!
Houston204 02-24-2013 01:48 PM
I'd pull new 8 conductor 18 gauge wire to the thermostat. This would allow for control of a humidifier or future upgrades.
Remove power to the furnace and write down the existing connections before removing any wires. I'd also snap a few pictures of the wiring.
nateonator 02-24-2013 02:19 PM
Thanks for the advice Houston. I will see about upgrading the wire.
gregzoll 02-24-2013 03:57 PM
As long as you try to keep some symmetry to the colors (R-Red, G-Green, Y-Yellow, W-White, so on). It is when you use different colors for different terminals, the next person may end up confused if they change it out.
rydan 02-25-2013 12:38 PM
Originally Posted by nateonator (Post 1123913)
Hi Everyone,
Thanks!
If your new thermostat is using batteries.. you won't have to use the common wire ( typically blue )
gregzoll 02-25-2013 07:47 PM
You may want to read up on the Nest. It uses a built in Lithium battery, but has problems with charging on certain hvac systems, so you need the C-Common wire to charge the battery in the device.
