Wiring My Thermostat...Please Help Solve Puzzle! :) - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-14-2010, 11:42 AM   #16
Ok, so I see where the destination of the 5 wires are.
1. Yellow is twisted around some other wire
2. Blue is tied into another (separate) white wire
3. Green is in terminal "G"
4. White is in terminal "W"
5. Red is in terminal "R"
According to the diagram for the new thermostat in my first post...I wouldn't use the "R" wire and would just leave the jumper in correct?
It says in the manual, "a jumper wire has been provided, connecting the RC and RH terminals for systems that do not provide both an RH and RC wire. If you have both an RH and RC wire, remove this jumper. If you do not have both an RH and RC wire, leave the jumper in place." I'm not seeing the RC/VC wire...so that's why I'm thinking I leave the jumper in?
Thanks so much for your help thus far guys....i'm learning a lot!
IdahoGirl is offline   Reply With Quote
Old 05-14-2010, 11:50 AM   #17
An old Tradesmen
Rewards Points: 8,234
At your thermostat.
Red to R
Green to G
White to W/B
Blue to Y/O
By rights, the blue and white wire at the furnace board, are suppose to be connected tot eh Y terminal.
But may have been bypassed for a reason we don't know.
Old 05-14-2010, 11:53 AM   #18
thanks a million....but...there isn't an "R" at the new thermostat terminals
would I just leave the red wire alone, keep the jumper in...and leave Y1 terminal empty?
Old 05-14-2010, 11:58 AM   #19
An old Tradesmen
LOL...
Sorry. I forgot they are listed differently. Connect the Red wire to either RC or RH. And make sure you leave the jumper connected to both RC and RH.
RC=Red cooling.
RH= Red heating.
Since you have both, you can connect the wire to either, as long as that jumper is there.
Old 05-14-2010, 12:00 PM   #20
great...thank you so much for the help. It's greatly appreciated!
just to confirm...the yellow wire will not be connected to anything right?
Old 05-14-2010, 12:09 PM   #21
An old Tradesmen
Correct. Its just wrapped around the sheath of the wire that goes to your outdoor unit. So it doesn't get connected to anything.
You will also want to look in your install manual, to see if there are any set ups you need to enter, or change on your thermostat for your system. probably not. But double check, just incase.
Old 05-14-2010, 12:21 PM   #22
thanks...
is this an electric furnace or gas furnace / oil burner?
also, is it a STD (standard) or HP (heat pump) ?
Old 05-14-2010, 12:24 PM   #23
An old Tradesmen
You have an induced draft 80% gas furnace, with straight/standard A/C(air conditioning) attached to it.
Old 05-14-2010, 12:44 PM   #24
again, beenthere, thank you...and thanks to everyone who helped...and a special thanks to the one who said I shouldn't do it
just finished testing it and it works great!
Old 05-14-2010, 12:47 PM   #25
An old Tradesmen
Good to hear.
Take care.
The Following User Says Thank You to beenthere For This Useful Post:
IdahoGirl (05-14-2010)
Old 05-14-2010, 03:37 PM   #26
All's well that ends well.
Just so I know what is riding on wiring a thermostat:
Is it possible to permanently damage a thermostat or furnace [besides a blown low voltage fuse] by hooking up the 'stat wires incorrectly?
How soon would you know about the damage?
Old 05-14-2010, 03:52 PM   #27
An old Tradesmen
Its possible.
You would generally know with in a few seconds to a few minutes of trying to run the system. Depending on what was wiring was wrong.
Old 05-14-2010, 04:04 PM   #28
I wonder if the OP really was a chick. So many guys pretend to be chicks because they think the Pros will flock to them with offers of help.
hvaclover is offline   Reply With Quote
Old 05-14-2010, 04:07 PM   #29
Originally Posted by beenthere View Post
Its possible.
With one right way and, dunno', 3 or 4 bad ways, and dozens or hundreds of non-working ways, this is a pretty interesting gamble, to save $200 or less.
And they're right!
Works every time!
The amount of blood in a man's body is not enough to run his brain and something else at the same time!
Old 05-14-2010, 04:11 PM   #30
An old Tradesmen
No different then when someone goes out and buys their own furnace heat pump or A/C. And then sizes and installs their own duct work.
A bad sizing and install can wipe out the equipment in just one or 2 seasons.
Today with forums. People can often get the help they need. Before they do damage.
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 06:11 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Thermostat wiring jetmanaz HVAC 1 08-09-2009 07:13 PM
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 07:04 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
