Wiring My Thermostat...Please Help Solve Puzzle! :) - HVAC - DIY Chatroom Home Improvement Forum
Old 05-13-2010, 10:12 PM   #1
Question
Hello all,
I'm in the process of replacing my old thermostat with an upgraded one.
I took off the old thermostat and realized I didn't mark how the wires were clamped on to it.
The old thermostat is a Honeywell Q539A1469.
Here is a diagram showing the old one and new thermostat
Is my wiring right??
I truly appreciate any help!!
Isabella
IdahoGirl is offline   Reply With Quote
Old 05-13-2010, 11:19 PM   #2
You're going to have to see what terminals the other ends of the wires are hooked up to, as your post doesn't give enough info.
hvac benny is offline   Reply With Quote
Old 05-13-2010, 11:23 PM   #3
thanks...additional pictures to come...
Old 05-13-2010, 11:52 PM   #4
Here's the blue wire...whats it going to?
Here's the yellow:
So on the thermostat there is one white wire....I'm seeing 2 white wires in the photo, so not sure which one it is:
Old 05-14-2010, 03:25 AM   #5
Yhat gas flex line is not code and shoule be removed for safety sake.
hvaclover is offline   Reply With Quote
Old 05-14-2010, 08:01 AM   #6
An old Tradesmen
Rewards Points: 6,892
Idaho.
The wires from your thermostat are connected to a control board in the blower compartment.
The ones you took pics of, aren't from your thermostat.
Old 05-14-2010, 09:02 AM   #7
i have no clue what your talking about...could you please provide a little more detail? thanks!
Originally Posted by beenthere View Post
Idaho.
where would I find my "blower compartment"? Thank you.
Old 05-14-2010, 09:47 AM   #8
fabrk8r
fabrk8r's Avatar
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 05-14-2010, 09:50 AM   #9
awwwww ok
i'll be back with more pics
Old 05-14-2010, 10:17 AM   #10
You've got guts, lady. . .
24vac is not too dangerous but watch out for sharp sheet metal edges.
There are only 6x5x4x3x2x1 ways, 720 of 'em, to hook up six wires to six terminals with only one wire on each terminal, so you need to get the colors right because only one way works properly.
Unfortunately, not every manuf. agrees on what color means what.
On top of that, sometimes wires are spliced inside the wall so the source color is not the same as the destination color.
On the bright side, it may not be possible to burn anything out no matter how you hook them up but I haven't checked all 720 combinations to see if this is true.
Old 05-14-2010, 11:00 AM   #11
Originally Posted by fabrk8r View Post
We went from real pics of the HO's furnace (An Amana) to a professionally shot still photo of a a Bryant/Carrier 80% furnace.
i feel so used
Old 05-14-2010, 11:08 AM   #12
How the heck do I get into the blower!?
Which side do I get into?
Old 05-14-2010, 11:08 AM   #13
i feel so used
But she didn't have a wedding ring on. Go for it!
Old 05-14-2010, 11:10 AM   #14
Don't do this. The odds against you are overwhelming.
Old 05-14-2010, 11:17 AM   #15
An old Tradesmen
You have a downflow furnace. Your blower is above the compartment you originally took pics of.
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 06:11 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Thermostat wiring jetmanaz HVAC 1 08-09-2009 07:13 PM
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 07:04 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
