Old 11-21-2008, 09:09 AM   #1
Wiring limit control on gas boiler
I'm Looking for some help on wiring up my boiler, I have 6 wires That connect to the limit & circulator dials .. I'm not certain as to where the to connect the gas wires & thermostat wires, The limit closes on rise & the circulator closes on rise.. I've tried to hook up the gas & thermostat on the limit dial .. But boiler kept on heating.. Triggered the pressure valve & had a big mess... I've tried to search for wiring diagrams on the internet.. but had no luck... Thanks
uncleneiler is offline   Reply With Quote
Old 11-21-2008, 01:18 PM   #2
Red face
not sure about having six wires but since i only see 4 contacts ill assume two of the thermo wires just get wirenutted the other 2 wires go on the limit (if the wires are the same colors match colors, if you have red and white than put the reds in a wirenut and break white thru the limit) on the circ one wire in (should be supplying 120v) and 1 wire out to circ pump
i think the limit should kick out at 180 and the circ on at bout 120
kennzz05 is offline   Reply With Quote
Old 11-21-2008, 02:54 PM   #3
An old Tradesmen
Limit should open on rise.
Thats how it shuts the burner off, by opening the circuit.
Might have a bad limit.
S9301A1001 Integrated Boiler Control Invisible-Man HVAC 3 03-31-2009 10:49 PM
Help with Wiring A Gas Water Boiler uncleneiler Plumbing 1 11-21-2008 12:05 PM
Wiring limit control on gas boiler uncleneiler Electrical 1 11-21-2008 09:03 AM
