Old 10-27-2012, 03:41 PM   #1
Wiring issue...
I currently have an issue with my Furnace blower.
When turning on the A/C everything appears to work fine. Blower turns on, no issues there.
When the heat attempts to kick on is where the problem exists.
The Igniter starts glowing then Gas kicks on flames going at this point no issues.
Then after about 10 seconds the blower motor attempts to turn on and right away the breaker is kicked of course turning all power off to the furnace.
Here is information on my blower.
Model = FASCO D701 (Model WG840587)
115 VAC 60 hertz
1/2 horsepower
1075 rpm
Three Speed
According to plate on motor Here is wiring info:
Brown----------------Capacitor
Brown/White----------Capacitor
White----------------COM
Black----------------HI
Blue-----------------MEDIUM
Orange---------------LOW
Red------------------S.LOW
Green/yellow---------GROUND
atc_parker05 is offline   Reply With Quote
Old 10-27-2012, 03:42 PM   #2
Wiring issue...
I have also tried connecting the red wire to the heat on the circuit board and the same thing happens.
Old 10-27-2012, 03:53 PM   #3
Houston204's Avatar
Wiring issue...
Does the back of the board appear burned?
Does the breaker trip with black at the heat terminal?
Houston204 is offline   Reply With Quote
The Following User Says Thank You to Houston204 For This Useful Post:
atc_parker05 (10-27-2012)
Old 10-27-2012, 04:15 PM   #4
Wiring issue...
Ok so with the black connected. It works just fine. No burn marks on the back of the board. I'm guessing it would be ok to leave it connected to the black...for heat then if i need cool to put it back? Also so I understand why do you think it would not work with the low or S.low wires.
Old 10-27-2012, 04:23 PM   #5
Houston204's Avatar
Wiring issue...
It's probably only the capacitor, but it could also be the motor that requires replacing.
I'd start with the cap. match the microfarad and voltage of the old one.
The right meter can read the capacitance but a new cap is much cheaper than a meter...
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 01:17 PM
Issue with thermostat wiring for baseboard heater jschell Electrical 3 01-30-2011 08:30 AM
GFI wiring issue voless Electrical 4 10-20-2010 02:37 AM
House electrical wiring issue. gnidaerd General Discussion 5 06-07-2009 03:42 AM
Century Home Wiring Issue fradam1976 Electrical 14 05-07-2008 02:53 AM
