Wiring For Honeywell Equip Interface Module THM5421C To Thermostat RTH8500 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-02-2013, 02:30 PM   #1
Wiring for Honeywell Equip Interface Module THM5421C to Thermostat RTH8500
So on the interface module and old thermostat everything is wired to 1, 2, and 3. Not exactly sure of what this is equivalent to on new thermostat.
So on the Equipment Interface Module from furnace I have coming in:
R Red
C Blue
W1 White
W2 Yellow
G Green
Wires from Thermo to Equip Interface module
1 red
2 white
3 green
The three wires are the same for the module and the old thermostat. My question is what do these relate to on new Thermostat Model RTH8500? Or do I have to redo and get a whole new Interface module? I have a dual stage fan which I believe is controlled by the white and yellow wires on module.
I do have on extra wire coming into house but have always just used three wires at the thermostat. My initial plan was to use Red to R, White to W, and Green to C.
Thanks in advance for any help, Bill
wgordon is offline   Reply With Quote
Old 12-02-2013, 06:29 PM   #2
An old Tradesmen
Rewards Points: 6,112
The RTH8500 is not a communicating thermostat, so can't use it will an EIM.
The Following User Says Thank You to beenthere For This Useful Post:
hvactech126 (12-02-2013)
Old 12-02-2013, 07:06 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Just to say again, you can't do that combination of EIM and thermostat.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-02-2013, 07:19 PM   #4
OK so in looking further I had 5 wires into house where thermostat was and they seemed to be all that was used on furnace it is High Efficiency Nordyne KG71L 080D.
Used on furnace....
R Red
C Blue
w1 White
w2 Yellow
g Green
Thermostat
R Red
c Blue
g Green
w o/b White
w2 e/aux Yellow
Then I thought correct settings in thermostat mods would be
170 4 (Heat only fan)
240 3 (more then 90% eff)
Constantly cycling on/off and the fast setting on blower/fan not kicking in.
Reason to replace LCD messed up on initial thermostat. Would like wifi in replacement not critical and definitely like the blower kicking in on high when returning to cold house. Not as important but nice. So did I totally blow it getting this thermostat?
Appreciate the comments and help. Seems pretty simple but typical home owner not liking results at this point!!
Old 12-02-2013, 07:39 PM   #5
AKA HVACTECHFW
fast setting on the blower? What is that exactly?
Even though you don't have cooling, the proper setup is:
170=8
180=0
240=3
IT IS WHAT IT IS
Old 12-02-2013, 07:51 PM   #6
Thank you
Appreciate the input...
Fast setting on blower....my version of two speed fan/blower. When the blower/fan initially kicks in if really cold in house it will kick in super high you can hear much louder, than as it gets warmer the fan/blower kicks down. Not sure how else to word it. Guess it is called variable speed blower..
Seems to be the solution!! thanks to all who provided help...
Old 12-02-2013, 07:53 PM   #7
AKA HVACTECHFW
With the previous settings it would not go into 2nd stage heat. It should with the new settings
IT IS WHAT IT IS
RTH8500 Wiring O and B Terminals dermanj HVAC 19 06-05-2016 03:55 PM
Wiring 2 baseboard heaters to 1 thermostat AlexandreSauve Electrical 7 04-16-2013 09:22 AM
I need help wiring my thermostat. batalbj1 HVAC 3 03-28-2013 11:30 PM
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 08:04 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
