Wiring Help For New Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2009, 06:36 PM   #1
Wiring help for new thermostat
I've had a cheap programmable thermostat (White Rogers 1F78-151) from the power company for a while and decided to install it. My motivation is simply to have the heat come up in the morning before I get out of bed. Anyway, the wiring on the current thermostat is as follows
Blue - W
Green - G
Red - R
White - C
Yellow - Y
The new unit has these terminals
W, RC, RH, G, Y, O, B RH and RC are jumpered out of the package.
The new unit looks to run on batteries but the current unit has no batteries.
JoBu is offline   Reply With Quote
Old 12-12-2009, 06:50 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
Use RWYG on the new stat and forget the C (tape it off). It allows the old one to run w/o batteries. Both work the same.Leave the Rc-Rh jumper alone and hook R to one of them.
Old 12-12-2009, 07:38 PM   #3
Thanks. As I understand it, the white wire to C on the old unit is for power to the unit itself. Since the new one runs on batteries it isn't needed - correct?
Old 12-12-2009, 07:43 PM   #4
Hvac Pro
yuri's Avatar
You got it.
Thermostat wiring question sob HVAC 11 10-21-2009 11:31 AM
Thermostat wiring question Yail Bloor Electrical 5 09-13-2009 02:57 PM
Thermostat wiring jetmanaz HVAC 1 08-09-2009 08:13 PM
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 08:04 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
