Wiring Help For New Hunter 44132 Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 09-04-2011, 06:18 PM   #1
Wiring help for new Hunter 44132 thermostat
Replacing old thermostat for Carrier heat pump (model 38nq024320). Old wiring to Honeywell q674l 1454 hh93az197 8629 was as follows:
White wire to O
Blue wire to W2
Orange wire to E
Green wire to G
Red wire to R
Yellow wire to Y
Brown wire to C
Been trying to figure out how to match wiring to new Hunter 44132 for over 2 hiurs....I need help. :-)
Wcavin is offline   Reply With Quote
Old 09-04-2011, 07:03 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
White wire to O
Blue wire to W2
Orange wire to E
Green wire to G
Red wire to R
Yellow wire to Y
Brown wire to C
Does the new stat have the same terminals?
White is usually heat, connected to the O terminal means that the reversing valve is energized when the call for heat is on at the heat pump.
Blue in this case is second stage heat, W2.
Orange would be emergency heat meaning if your heat pump breaks down you can utilize your electric heat strips in the furnace, or natural gas or whatever is back up heat.
G is fan, turns on the blower under any call, fan on , cool or heat.
R is power/24 volts.
Y is cooling mode.
Brown is being used as common.
Doc Holliday is offline   Reply With Quote
Old 09-04-2011, 07:12 PM   #3
On new thermostat the terminals are as follows:
R
Y
G
W
L
O
B
A/E on one side, W2 on other
Y2
C
A
Old 09-04-2011, 07:20 PM   #4
R
Y
G
W
L
O
B
Y2
C
A
Orange to Auxilary/Emergency heat.
Blue to W2.
You are not using B, Y2, L or A on the new stat.
Brown to C which is common, as is what was hooked up in the old stat.
The rest will be the same as the old stat as well.
Old 09-04-2011, 07:31 PM   #5
O and B are reversing valve calls. The reversing valve is located in the heat pump and is "told" to come on/switch either during the call for cool or the call for heat.
You had on your old stat the W/heat wire hooked to the O so start there, meaning in call for heat the reversing valve switches to produce heat. The refrigerant switches it's direction for heat, why it's called a reversing valve.
Y2 would be second stage cooling and you do not have that to begin with.
I have no idea what L or A are as I don't have the paperwork in front of me as you do but if it wasn't there to begin with, don't think about it. Not every terminal needs a wire hooked to it.
Old 09-04-2011, 07:40 PM   #6
Doc....
In think that did it. I appreciate the help.
Old 09-04-2011, 07:51 PM   #7
Glad to help.
question on old thermostat wiring for upgrade jthn HVAC 2 01-03-2011 12:07 AM
Problem Wiring Thermostat MichaelLR Electrical 9 12-20-2010 04:20 PM
Thermostat wiring question tgeb HVAC 3 11-19-2010 05:08 PM
Thermostat Heat Pump Wiring difficulties akg4y HVAC 8 04-15-2010 06:16 AM
Thermostat wiring help sords HVAC 10 01-01-2010 02:45 PM
