Old 10-26-2012, 03:50 PM   #1
wiring furnace transformer
Hi all, I am trying to install a new transformer on my furnace and well the new transformer does not have the labels my old one did, COM , COM , 120v, 24v. Here is a picture of the transformer it only shows LOAD, LINE but doesn't specify which lead is exactly what.
Also I have attached a second picture of my old transformer.
Thanks for any help.
jasonbaur is offline   Reply With Quote
Old 10-26-2012, 03:55 PM   #2
I'm Your Huckleberry
Do you have an electrical meter? Line is where the high voltage goes in. Once that's there I'd test the other terminals to make sure 24 volts is coming out, the load side.
Line is the feed, load is the work being performed from the said feed. In this instance it's a step down 120 volt to 24 volt tranny, 24 volts being the load.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 10-26-2012, 04:09 PM   #3
Ya the line is ok not sure why the old transformer finally gave out. Anyhow ya my best guess is the top 2 ports are the 24v and com, the bottom is the 120v and com, no idea if it matters left or right or right to left I hate how they aren't labeled specifically.
thanks.
Old 10-26-2012, 04:21 PM   #4
JJboy's Avatar
black/white wires use to 120v
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-26-2012, 04:44 PM   #5
An old Tradesmen
As long as you connect the 120 volt to the 120 volt terminals, it doesn't matter which wire goes where. Its just a coil of copper wire wound around an core.
Trane gas Furnace wiring issue Praetor HVAC 6 08-13-2012 08:31 AM
Wiring low voltage lights in garage, where to put the transformer htabbas Electrical 10 08-02-2012 04:51 PM
Is it normal to have the furnace control panel wiring, not match the wiring diagram cjbeck71081 HVAC 6 07-18-2012 12:19 PM
checking transformer voltage-Heil gas furnace chuck59 HVAC 0 09-07-2011 04:39 PM
transformer and circuit brd in gas furnace gulley HVAC 5 11-22-2010 12:48 AM
