Wiring For Fan Only On Electric Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 09-25-2010, 06:44 PM   #1
wiring for fan only on electric furnace
I have an old wesco furnace model bru 1500 in my mobile home. It is already wired with 5 wire to the thermostat, but I only use two because it is a heat only system. Now I want to wire up the option on my thermostat to run fan only...Anyone know how to do that? thanks
thewhitemacho is offline   Reply With Quote
Old 09-25-2010, 08:04 PM   #2
Rewards Points: 492
If one of the wires is clearly marked 'G', that's the one that goes to the thermostat 'G' terminal.
diyorpay is offline   Reply With Quote
Old 09-26-2010, 08:15 PM   #3
There are only two terminals on the furnace end. And they are already hooked up by the two wires needed to run normal furnace function. So where do i hook up the green on the furnace end?
Old 09-29-2010, 08:26 PM   #4
Rewards Points: 492
Post
In my furnace the low voltage terminal board receiving wiring from thermostat is riveted to side of wiring box (not control board). Assume W and Y are your 2 terminals for heat. Typically other terminals are C (not used on mine) and G for fan. Total of 4. When the fan switch is thrown on thermostat only the fan goes on if the G wire is connected. Probably overrides all safety checks for ignition etc because it's just a fan. With no G terminal you won't be able to run fan only.
Old 09-29-2010, 09:40 PM   #5
HVAC / Plumbing
If it's an old motor .It may only be single speed. G brings in high speed which he may not have
kenmac is offline   Reply With Quote
Old 09-30-2010, 09:26 AM   #6
newtech's Avatar
Rewards Points: 164
The G terminal energizes a fan relay. It doesn't have to be a multispeed motor.
newtech is offline   Reply With Quote
Old 09-30-2010, 09:28 AM   #7
newtech's Avatar
Rewards Points: 164
Can you post a pic of where your t-stat wires are connected in the furnace?? Do you have a circuit board?
Old 09-30-2010, 10:33 AM   #8
HVAC / Plumbing
Yes, I know that. I should worded it a little different. His unit may not be set up to use fan only if he is heat only & is an older type furnace. He may just have a time delay relay, etc, that brings fan on since he says it's older & is heat only. I'm not saying it cant be wired to work.
Old 09-30-2010, 02:45 PM   #9
here is a picture of where the wires connect to the furnace.
Old 09-30-2010, 05:56 PM   #10
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
It is a basic electric furnace that has no fan relay and G and is not prewired for AC. The sequencers for the heat strips turn on the fan. No way to run the fan unless a fan relay is installed and a bunch of wiring altered by a Pro who does electric furnaces.
That furnace may not be very safe to use as one of the elements can short out soon due to age and drop to the next one and start a wiring overload and fire. I have seen plenty of roasted electric furnaces. For safety reasons I would buy a new Miller or Intertherm and it will have a G terminal etc.
The Following User Says Thank You to yuri For This Useful Post:
thewhitemacho (09-30-2010)
Old 10-02-2010, 11:25 AM   #11
Thanks for the help, What about this option, I should be able to wire in a standard toggle switch just outside the furnace on the wall that runs the fan only right? So it would be bypassing the furnace and just engaging the fan. Just wire a switch that takes power from somewhere inside the furnace, ( im sure i could find a 110 lead in there somewhere) and just wire it up like a standard house 110 switch. am I off base here? that would work right? That is, if the fan is 110.thanks...
------Tighten it till it strips,back off a 1/4 turn-------
Old 10-02-2010, 11:40 AM   #12
Hvac Pro
yuri's Avatar
Nope, the fan is 220 volts. Any altering and you could backfeed power to the motor or elements and damage them. Sorry.
Old 10-02-2010, 12:06 PM   #13
Right, back feed, good point, so for the sake of making it possible, you could have a switch that kills power to the fan first, then re-energizes it with another switch, a what, two pole 220v switch right?( the green ones i think), or if they make a switch that does that all in one.....Is this dangerous? lol...I know my way around wiring pretty well,ac house current that is....thanks
-----tighten it till it strips,back of a 1/4 turn-----
Old 10-02-2010, 12:38 PM   #14
Hvac Pro
yuri's Avatar
Hard to see it from here. A green one? Homemade wiring tends to catch on fire from what I have seen and the fire marshall/ins co. don't care for it either.
Old 10-02-2010, 12:50 PM   #15
True that....thanks
Tags
fan , thermostat , wesco
Wiring for electric range rgustavw Electrical 2 09-21-2010 03:18 AM
Ruud Electric Heating Furnace jacksadvantage HVAC 3 01-15-2010 05:56 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
electric furnace not shutting off pkuenz HVAC 5 11-17-2008 05:22 PM
electric furnace need help Unregistered HVAC 3 10-16-2007 03:41 AM
