Wiring Diagram 48gs030060301 - HVAC - DIY Chatroom Home Improvement Forum
Old 07-29-2011, 10:12 AM   #1
Rewards Points: 150
wiring diagram 48gs030060301
I cant seem to find a wiring diagram for a carrier package unit model 48gs030060301.
Any clues?
wetbar is offline   Reply With Quote
Old 07-29-2011, 10:59 AM   #2
REP
There should be one on the inside of the panel of the outside units electrical panel.
REP is offline   Reply With Quote
Old 07-29-2011, 11:05 AM   #3
Rewards Points: 150
Yeah, You would think so. I have looked all over for it and cant find it
Old 07-29-2011, 09:10 PM   #4
newtech's Avatar
Rewards Points: 164
See if this will help.
newtech is offline   Reply With Quote
Old 07-30-2011, 12:20 AM   #5
Rewards Points: 150
Oh man that is close, but not quite. I cant not believe this thing does not have a low freon sensor, but I cant find it. It would have to go between the t-stat yellow wire and the contactor right? ... but even the diagram above the yellow wire comes from the t-stat staight to the contactor, and the other side is 24V common. So no matter what, when the t-stat is calling, the contactor will be energized. Maybe that is why I had to replace the compressor. :-(
Old 08-01-2011, 10:56 AM   #6
Rewards Points: 150
Any clues?
Old 08-01-2011, 11:28 AM   #7
JJboy's Avatar
high/low pressure switch are sensor connected on the line set at the condenser
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-01-2011, 04:16 PM   #8
newtech's Avatar
Rewards Points: 164
Not all Carrier units came with a LPCO.
So yes, if you had a leak and ran the system with out any R-22..... You could burn up a compressor....
Day & Night furnace wiring diagram Paul Dahlin HVAC 9 03-03-2011 10:08 PM
Sprinkler control wiring re-connect (diagram) ScottR Plumbing 4 06-25-2009 09:51 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
Wiring diagram for lights with two switches Ed M Electrical 7 08-10-2008 09:59 AM
Celiera 18000 Split AC/Heatpump, power wiring diagram? trinhyulinh HVAC 2 08-03-2008 01:36 PM
