Wiring Dehumidify Function On Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2012, 11:46 PM   #1
Wiring Dehumidify Function on Thermostat
I am trying to figure out how to wire my carrier edge thermostat to take advantage of my furnace dehumidify function. I know that the connection from dry contact #2 goes to the furnace dhum terminal but my question is what do I do with dry contact #1? It appears from the wiring diagram that it should connect with the RH wire but I am unfamiliar with the wiring symbol that is used at the point of connection. What does this symbol mean?
My setup is listed in figure 30 on page 75 of the attached manual.
http://www.docs.hvacpartners.com/idc...p-prh-07si.pdf
uga1985 is offline   Reply With Quote
Old 10-26-2012, 12:07 AM   #2
It's just means that the wires are connected at that point
weebo_21 is offline   Reply With Quote
Tags
hvac
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 10:53 AM
question on old thermostat wiring for upgrade jthn HVAC 2 01-02-2011 11:07 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Thermostat to Controller Wiring Molson HVAC 1 07-05-2010 06:24 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
