Wiring To Control Board And Thermo Stat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2012, 09:26 PM   #1
wiring to control board and thermo stat
I have 58MCA060-12 carrier furnace. some time ago, the control board HK42FZ011 was burned out now i replaced it . I jumped red and white and it works fine .I have difficulty in connecting the wires on control board . I have three set of cable at furnace which were connected to control board. I have central air heating. one cable has 3 wires green black and white. other cable has black and white and the 3rd cable has only black wire. how these wire shold be connected at furnace control board and the on the other end to the thermostat.my thermostat is noma 52-2558-8. you guys are great help. thank you
dijas is offline   Reply With Quote
Old 10-27-2012, 09:37 PM   #2
Rewards Points: 296
those wire colors are messed up...you need to match r,wy,g from thermostat to control board r,w,y,g it would be great if you could pull new 18-4 stat wire colored coded....ben sr
Old 10-27-2012, 09:56 PM   #3
thanks ben I figured it out and every thing is working fine. Thanks for your help
The Following User Says Thank You to dijas For This Useful Post:
ben's plumbing (10-27-2012)
Carrier Control Board Fuse Blows kdljet HVAC 5 03-11-2009 10:20 PM
