Wiring A Amana PTH123E35AXXX Remote T-stat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 02:02 PM   #1
34Ford's Avatar
Question
Wiring a Amana PTH123E35AXXX remote t-stat
I have a new Amana PTH123E35AXXX and the 1246004 digital programmable t-stat I want to connect but the instructions that came with each just confused me.
And I dont want to damage something.
The main heat pump has connectors C R GL W2 Y/W1 B GH
The t-stat has C C R on one block and Y2 Y1 W1 G W2 O B on the second block.
Thanks,
Dennis
34Ford is offline   Reply With Quote
Old 01-21-2012, 04:06 PM   #2
I dunno. Maybe one of the other guy do.
I'll get someone for you.
hvac5646 is offline   Reply With Quote
Old 01-22-2012, 11:26 AM   #3
Houston204's Avatar
Rewards Points: 556
Looks like you have to choose between high fan (GH) and low speed fan (GL).
HP = stat
C = C
R = R
GL = G
W2 = W2
Y/W1 = Y1
B = B
I found nothing online about the second C terminal on the stat.
I couldn't even get an installation guide for the configuration settings.
The newest ptac manual I found is 2009.
What year is listed on the bottom of your first page?
Houston204 is offline   Reply With Quote
Old 01-23-2012, 09:14 AM   #4
34Ford's Avatar
To maybe help show what I have, here is the t-stat Im going to use.
And also a pic of the instructions with the HP.
I guess I will do it like you show and leave the Y2 unconnected.
Old 01-26-2012, 05:01 PM   #5
34Ford's Avatar
Well I wired it up, the low voltage wire kit came and all seems to be working except for the "aux" led in the t-stat dont light when I force the unit to heat when using the heat strip.
Surely thats not the "C" connector I didn't connect.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Honeywell stat wiring w/ Trane furnace JaePee HVAC 7 01-18-2009 06:50 AM
UPS powering remote devices using house wiring MusicMan_234 Electrical 16 01-07-2009 06:56 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
