Wiring For Air Handlers? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-29-2008, 10:32 AM   #1
wiring for air handlers?
Are the air handlers 110 or 220? Or do they vary for size? Thanks.
737Pilot is offline   Reply With Quote
Old 09-29-2008, 06:39 PM   #2
Electrician
They can be either or...
chris75 is offline   Reply With Quote
Old 09-29-2008, 08:44 PM   #3
biggles's Avatar
most units at that end are 115V with the fan motor/TR being the main load.if you get involved with heat pumps 220V might be used for the resistance heaters as back up heat.
Old 09-29-2008, 09:18 PM   #4
Electrician
Not true at all, I get all types, simple hydro air units at 240 volts, all depends on the manufacture, and thats about it.
Old 09-29-2008, 09:50 PM   #5
Rewards Points: 398
He didn't say all. I would say his statement is accurate. The majority of furnaces, hydronic, and no heat units are going to be 115v. Heat pump units with electric backup heat are going to be 230v. It doesn't depend on the manufacturer; it depends on what type of air handler you order.
Malcolm is offline   Reply With Quote
Old 09-29-2008, 10:53 PM   #6
Electrician
And I'll still disagree. We dont use heat pumps up north, but for what its worth I've wired just as many 240v blowers as I have 120v ones, and thats all i'm pointing out.
The OP's question is a simple one, the answer is this, the unit is what it is.
Old 09-30-2008, 10:55 AM   #7
Rewards Points: 398
That's odd. It must be based on location. In my area, ninety nine percent of furnaces are 115v. One hundred percent of heat pumps are 230v. The only thing that differs is hydronic heat and no heat applications. These are either 115 or 230v (majority 115v). This can be attributed to future needs of the system.
Old 09-30-2008, 07:13 PM   #8
Electrician
We're not talking about furnaces, were talking about hydro-air units. At least I think we are? If that helps any. I agree, I've never wired a 240v furnace, but hydro air units (Air Handlers) come in any flavor.
Old 09-30-2008, 10:33 PM   #9
Idiot Emeritus
Rewards Points: 1,492
I think every furnace (which includes an air handler, and some sort of heating system) I've ever installed has been 120 volt. These are commonly used in conjunction with a remotely located heat pump, or A/C unit, which is always 208-240 volt.
Air handlers, which have coils (radiators) in them that circulate hot or cold liquids, come in all sizes and voltages. I've connected huge ones that had 300HP motors that operated on 4160 volts, as well as small ones that operated on 120. Some are dual voltage.
The only way to know for sure is to either look at the unit when it arrives, or look at the spec sheet for the unit that was ordered.
Rob
micromind is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Electrical problem, bad wiring? mumblemouth Electrical 10 08-09-2008 12:52 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
