Wiring For AC - HVAC - DIY Chatroom Home Improvement Forum
Old 05-20-2012, 02:00 PM   #1
Rewards Points: 190
Wiring for AC
Hi!
My dad has his furnace replaced a few months ago, and they never wired the thermostat to the furnace to the a/c. From what I've read, there should be a yellow and a black that gets wired to the furnace. Unfortunately, there's two yellow wires going to the AC unit.
I was hoping somebody could suggest which is the yellow and which is the black. Does it matter? There's only two wires for the AC, right?
Thanks!
wiz561 is offline   Reply With Quote
Old 05-20-2012, 02:16 PM   #2
Rewards Points: 6,652
Close your eyes and grab the first one. You can call it Yellow, you can call it Black, you can call it Red, You can call it Blue. Hell, you can call it any color in the Crayola Crayon box, it really does not matter what color you call it, just pick one.
Old 05-20-2012, 02:28 PM   #3
Rewards Points: 190
So, from what it sounds like, the color and scheme doesn't matter to the AC? Is there a way you can reverse wire it and blow something?
Thanks for the response!
Old 05-20-2012, 02:43 PM   #4
Only if you connect one of the hots for the 240vac circuit to one of those wires. Then maybe you will hear a loud pop and see the release of the magic smoke.
The Following User Says Thank You to gregzoll For This Useful Post:
Ravenworks (05-21-2012)
Old 05-20-2012, 02:44 PM   #5
Rewards Points: 190
Thank you so much for the information. We'll have to give that a shot.
I'll stay away from the 240. :D
Thanks again!
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
