Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2009, 07:03 PM   #1
wiring
installing to zone valves, do they require there own power supply, or can i just wire them to the aquastat? honeywell aquastat l8148e and zone valve honeywell yhv8043e1012...( it has 2 red wires that go to pump and 2 yellow wires that gos to themostat) thanks for any help
buck545 is offline   Reply With Quote
Old 10-23-2009, 08:23 PM   #2
GetYourShineBox's Avatar
yes they require a transformer.
your red wires are your end switch, they go to T , T on your circulator relay.(wire your zone valve end switches together then run your red wires to T, T.) Your yellow wires go to your zone valve t-stats and transformer. one yellow wire goes to common of the transformer, the other yellow wire goes to W on your zone valves thermostat and then you will run a wire from R on your thermostat to R of the transformer. since you are wiring up two zone valves, the wires coming out of R on your thermostats will be wired together and then wire nutted to the wire comming out of R on your transformer. your yellow wires coming out of your zone valves will be wired together and then wire nutted to the wire coming out of C(common) of your transformer. hope this makes sense to you.
GetYourShineBox is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
