Wiring 2 Hi/low/limit Switches In Parallel - HVAC - DIY Chatroom Home Improvement Forum
Old 12-09-2008, 07:16 AM   #1
When is fishing season?
CowboyAndy's Avatar
wiring 2 hi/low/limit switches in parallel
Okay so after trying to dial in my new furnace still, I am noticing something. the fan switch is located at the back of the plenum. the wood fire box is in the front. almost all of the ducts are towards the front.
I have been noticing that the front of the plenum is significantly hotter than the back where the fan switch is, also the part of the room where the front of the furnace is warmer than the back because of the door on the firebox.
Make sense so far?
I think that the temp settings are skewed and messing things up. I have it set at low 100, hi 150 and limit 230, but i am gessing that the front of the plemun is probably more like 165-175 before the back is 150.
My uncle suggested adding a second fan switch in the FRONT, wired in parrallel to the existing one, so that the rear one would be more acurate for when the oil burner comes on.
how would I wire it in parrallel? should I ask this in electrical wiring instead?
btw, the furnace is a newmac wood/oil combo
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 12-10-2008, 12:12 PM   #2
An old Tradesmen
Rewards Points: 8,202
If the fan limit wires are in a juntion box.
Just run a second set of wirs from the new fan limit to the same juntion box, and tap into teh wires hooked to teh fan side.
DO NOT parralel wires with the liimt.
Old 12-11-2008, 09:08 AM   #3
CowboyAndy's Avatar
Maybe I used the wrong word, should have been series?
Anyhow, the wires going to the current switch do come from a jbox, but there is alot going on in there and I think I may be over fill if I add more...
MY HOUSE OWNS ME!
Old 12-11-2008, 01:50 PM   #4
An old Tradesmen
In series. The fan wouldn't come on until both fan controls are calling.
You could wire the fan side parralel, and the limit in series.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
wiring switches Dean1234 Electrical 2 11-01-2008 11:46 PM
Wiring diagram for lights with two switches Ed M Electrical 7 08-10-2008 08:59 AM
parallel / series wiring question geetee Electrical 5 06-11-2008 02:42 PM
wiring two switches and two fans rtyui2 Electrical 1 11-22-2007 04:32 PM
