Wiring 2 In 1 Cap In Parallel - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2009, 03:18 PM   #1
wiring 2 in 1 cap in parallel
I have a 40 + 5 and a 40 mfd cap. I need a total mfd rating of 80 mfd. I want to wire the 40 mfd 2 in 1 cap and 40 mfd single cap in parallel. As you know, the fan shares the common wire on the 2 in 1 cap. I just want to make sure it doesn't interfere with the capacitance for the condenser motor.
pomelo is offline   Reply With Quote
Old 06-23-2009, 03:46 PM   #2
Should be good to go.
SKIP4661 is offline   Reply With Quote
Old 06-23-2009, 05:55 PM   #3
Are the voltage ratings for each cap high enough for the application?
Old 06-23-2009, 06:28 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
In parallel it will still be 40 mfd
Series will be 80 mfd
Basic electrical..
However I don't know how long it will last...
Old 06-23-2009, 07:13 PM   #5
"Capacitors in a parallel configuration each have the same applied voltage. Their capacitances add up. Charge is apportioned among them by size. Using the schematic diagram to visualize parallel plates, it is apparent that each capacitor contributes to the total surface area."
Old 06-23-2009, 07:38 PM   #6
Rewards Points: 560
Yoyitiz,
I stand corrected. I just went to the service truck and connected two 5 mfd in parallel and you are right 10 mfd.
Just did think hard enough
Old 06-23-2009, 07:43 PM   #7
An old Tradesmen
Rewards Points: 6,544
And a 12.5 and 20 wired in series will give you 7.69, whihc is close enough to 7.5 when your ouot in the boonies, and don't want to run 20 miles for a 7.5.
And don't have 2-15s to use.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
wiring 2 hi/low/limit switches in parallel CowboyAndy HVAC 3 12-11-2008 02:50 PM
parallel / series wiring question geetee Electrical 5 06-11-2008 03:42 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
